Description
The script is designed to quickly decode the ASCII-encoded Base64 data highlighted in the EnCase GUI.
In ideal circumstances, the amount of data highlighted should be an exact multiple of 4 bytes (excluding carriage-return, line-feed, tab and space characters). If not, the script will pad the data with one or more '=' characters.
The script will write hex and low-ASCII respresentations of the decoded data to the console; it will also (optionally) write the data to a nominated file.
This script was developed for use in EnCase training. For more details, please click the following link:
Releases
Release
Size
Date
Quick Base64 Decoder 3.1.0
122.4 KB
Sep 25, 2025
More info Less info
Product compatibility
Version 1.0.0
Release notes
This release fixes a bug whereby an additional null byte was added to the output stream if the input stream was an exact multiple of 4-bytes.
Tested with OpenText Forensic (EnCase) 25.3.0.85.
Languages
English
Marketplace Terms of Service
In order to continue, you must accept the updated Marketplace Terms of Service.
Your download has begun...
Related content and resources
release-rel-2026-03-01-6485 | Fri Mar 20 10:30:32 PDT 2026
